Auto Configure Failed
ckariappa
When i try to login to ThingWorx Studio at the "Configure ThingWorx Studio", I get the "Auto Configure Failed. Check log for errors" message.
Please find the attached Logs and Screenshot.
6 REPLIES 6
posipova
20-Turquoise
(To:ckariappa)
Moved to Thingworx Studio space.
Hi Chirag, Based off the log file you shared, there seems to be a connectivity issue. Could you please try configuring Studio on a different network?
ploney
(To:ckariappa)
I have the same thing.  Bad word choice.
I have the same error .
[16:17:50] Studio Version 1.12 (0.1.16.1485)
[16:17:50] Status Message: Version 1.12 (0.1.16.1485)
[16:17:50] Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
[16:17:51] Status Message: Performing First Time Setup (Application)...
[16:17:51] Unzipping mbdist.zip to C:\Users\00a3926\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\
[16:17:54] Status Message: Performing First Time Setup (Libraries)...
[16:17:54] Unzipping mbmodules.zip to C:\Users\00a3926\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\
[16:18:54] Skipping Zero Byte File: node_modules\editorconfig\tests\
[16:21:17] Starting node.exe
[16:21:25] info: [twx-studio:initializer] Node version: 6.9.1
[16:21:25] info: [twx-studio:initializer] ThingWorxStudio launched with the following arguments: _=[C:\Users\00a3926\Documents], $0=..\..\..\..\..\..\Roaming\ThingworxStudio\studio-download.vuforia.io\dist\server\index.js
[16:21:25] info: [twx-studio:initializer] ThingWorxStudio dir:  C:\Users\00a3926\Documents\ThingWorxStudio , home dir: C:\Users\00a3926\Documents
[16:21:35] ar-extension version 1.12.463
[16:21:36] info: [twx-studio:index] *********** Preview listening on 127.0.0.1:4001
[16:21:36] info: [twx-studio:index] listening on 127.0.0.1:3000
[16:21:39] Proxying: http://localhost:3000
[16:21:39] Access URLs:
[16:21:39]  ----------------------------
[16:21:39]  Local: http://localhost:3001
[16:21:39] Watching files...
[16:21:39] Status Message: Version 1.12 (0.1.16.1485)
[16:21:39] Proxying: http://localhost:4001
[16:21:39]  Local: http://localhost:4000
[16:21:39] error: [twx-studio:sockets] clientSocket undefined, unable to emit  UpgradeInProgress
[16:21:39] info: [twx-studio:upgrade:StudioSample3DImport] Upgrading project Studio Sample - Import 3D Data C:\Users\00a3926\Documents\ThingWorxStudio\Projects\StudioSample3DImport from 1.8.279 to 1.12.463
[16:21:39] info: [twx-studio:upgrade:StudioSampleQuadcopter] Upgrading project Studio Sample - Quadcopter C:\Users\00a3926\Documents\ThingWorxStudio\Projects\StudioSampleQuadcopter from 1.8.279 to 1.12.463
[16:21:41] info: [twx-studio:upgrade:StudioSampleQuadcopter] Building ves-ar-extension app: Studio Sample - Quadcopter
[16:21:42] info: [twx-studio:upgrade:StudioSample3DImport] Building ves-ar-extension app: Studio Sample - Import 3D Data
[16:21:45] info: [twx-studio:upgradeProject] Upgrade log saved to C:\Users\00a3926\Documents\ThingWorxStudio\Projects\StudioSampleQuadcopter\upgrade.log
[16:21:45] info: [twx-studio:upgradeProject] Upgrade log saved to C:\Users\00a3926\Documents\ThingWorxStudio\Projects\StudioSample3DImport\upgrade.log
[16:22:22] [0mGET /%7B%7BprojectType.imgPath%7D%7D [32m200 [0m5.822 ms - 2035[0m
[16:22:22] [0mGET /%7B%7Bview.imgPath%7D%7D [32m200 [0m7.211 ms - 2035[0m
[16:22:22] [0mGET /%7B%7BviewType.imgPath%7D%7D [32m200 [0m0.845 ms - 2035[0m
[16:22:22] [0mGET /images/%7B%7Bw.name%7D%7D.png [32m200 [0m2.445 ms - 2035[0m
[16:22:28] info: [twx-studio:logging] Overwriting env DEBUG  info:ves-publish*,error:ves-publish*,undefined  with new value
[16:22:28] info: [twx-studio:logging] Debug logging disabled
[16:22:43] error: [twx-studio:auto_configure] 500 'Unable to retrieve service details.' Error: getaddrinfo ENOTFOUND studio.thingworx.com studio.thingworx.com:443
[16:22:43]     at errnoException (dns.js:28:10)
[16:22:43]     at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:76:26)
[16:22:43] [0mGET /api/autoConfigure [31m500 [0m106.795 ms - 58[0m
[16:22:43] error: [twx-studio:index] unhandledRejection Unable to retrieve service details.
tmccombie
(To:ploney)
Check out our knowledge article about this issue. Let me know if you run into any problems. ThingWorx Studio Failed Connection Issues
ploney
(To:tmccombie)
Got a little further.
Plugged in the Proxy URL and the default experience url.
Am now getting a new error below, certificate related.
FYI on a second machine I tried chrome and got the same thing.
[14:39:23]  [0mGET /api/autoConfigure  [31m500  [0m512.769 ms - 58 [0m
[14:43:25] debug: [twx-studio:auto_configure] dev_portal_url https://studio.thingworx.com/api/v1
[14:43:25] error: [twx-studio:auto_configure] 500 'Unable to retrieve service details.' Error: unable to get local issuer certificate
[14:43:25]     at Error (native)
[14:43:25]     at TLSSocket.<anonymous> (_tls_wrap.js:1062:38)
[14:43:25]     at emitNone (events.js:86:13)
[14:43:25]     at TLSSocket.emit (events.js:185:7)
[14:43:25]     at TLSSocket._finishInit (_tls_wrap.js:586:8)
[14:43:25]     at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:416:38)
[14:43:25]  [0mGET /api/autoConfigure  [31m500  [0m450.718 ms - 58 [0m
[14:43:25] error: [twx-studio:index] unhandledRejection Unable to retrieve service details.
[14:43:27] debug: [twx-studio:logging] Debug logging enabled. DEBUG=twx-studio*,ar-extension*,ves-publish*
[14:43:27] Wed, 17 May 2017 21:43:27 GMT twx-studio:logging DEBUG_FD=1 so the "debug" module will log to stdout instead of stderr
[14:43:30] debug: [twx-studio:sockets] EMIT builderSettings
Swaroop
2-Explorer
(To:ploney)
I could resolve this by simply moving to Wifi instead of my office LAN. There are different level of restrictions on these two is what i was aware of.
Swaroop
