Binding Properties not appearing
AS_9877774
7-Bedrock
Hello Community,
I was trying to bind the visibility property of a 3D image to a toggle Button.
The properties are not getting listed as in the below image.
It is the same in case of a 2D image also.
What could be the reason and how to solve it ?
Thanks.
ABHIRATH
Hey..
Worked while drag and dropping the pressed arrow.
2 REPLIES 2
just to make sure: Did you drag'n drop the arrows-icon in front of "value" or did you try the click-event? First one works at my project.
Hey..
