when I set the scale of a Model to 1:100, it doesn't show up in the experience. Scale 1:10 works nicely. By typing in a Thingmark Width that's 10 time the actual size, we can make the experience work properly.
For information: this model is quite large, appr. 90 meters.
Jaap
@jkramer I will check this if we can set 1:100 value or not our Product team and will get back to you with more details.
I believe you are able to get the experience loaded with 1:10 and it's just that 1:100 do not work . Correct?
-Durgesh
Hello Durgesh, yes, that's correct, thanks for testing!
Jaap
