In the latest version of ThingWorx Studio 8.2.2 the css for PopUp no longer works.
in the previous one I used the following CSS to animate the Popup window, after the update the show / Hide animation does not work anymore.
CSS Used
.twx-popup-container {
transition: -webkit-transform .5s cubic-bezier(.455,.03,.515,.955);
transition: transform .5s cubic-bezier(.455,.03,.515,.955);
transition: transform .5s cubic-bezier(.455,.03,.515,.955),-webkit-transform .5s cubic-bezier(.455,.03,.515,.955);
-webkit-transform: translateX(0) translateZ(0);
transform: translateY(0px) translateZ(0);
.twx-popup-container.hidden {
display: block !important;
-webkit-transform: translateX(250px) translateZ(0);
transform: translateY(-600px) translateZ(0);
Has something changed ?
Giuseppe
I asked development and he suggested to use instead the angular ng-hide.
So I tested your css now in the modified version and it does animate. I am not sure if this is the correct/ desired apperance. Could you test it, please, and let me know!
Here the modified version:
.twx-popup-container.ng-hide {
Hi Giuseppe,
Are you using the PopUp widget or $ionicPopup? Are you receiving any errors after upgrading?
i used the PopUp widget .
News for this Problem ? 😞
Do you see any errors in the console when viewing the project in preview?
in generally it seems that popup widget is working with style .
For example the following style:
.test1{
width: 40%;
border: 5px solid red;
-webkit-transition: width .35s ease-in-out;
transition: -webkit-transform .8s cubic-bezier(.455,.03,.515,.955);
.test1:hover{
width: 90%;
border: 8px solid yellow;
adding to Applicaiton and then set the popup class property will work as expected:
So means that the style definition is working fine for this style in this case.
I tried to use the your style definition in chrome as general style but it was not working.
When I tried to use your style it moves the element on the top but I did not see any otters effects. What should it do?
How did you generate the mention style and in which version was it working?
The problem is that up to the previous version, that style I wrote, scrolled the
popup animating it ( ver. 8.2.1 Thingworx Studio) ,in the last versione ( 8.2.2) the effect of the animation no longer exists,
but appears as if it were a simple hide / visible, without animation.
using ng-hide and no longer hidden works great, thanks 1000
Giuseppe
