I'm using vuforia and unity(2022.3.16) together to do my final year project. when in play mode, the application works however, after i've built the app, installed it on an android phone and given camera access, the screen is black. I can see on the top right corner there's a button I added to the canvas so I'm pretty sure the issue is with the camera. Please help as I do not understand where I went wrong.
Take a look:
Take a look:
Thank you for the links. I appreciate it
Hi @RI_11033164 ,
this communty is for Vuforia Stuido / but also ,Vuforia Editor/Capture and Chalk /the other vuforia groups. Here are Engine issue are no really handled here(only in case that it is related to Vuforia Studio) So that when you have an Unity application on Android then it is betther to use as @VladimirN mentioned the Vuforia Dev forums to ask/ report a question:
Community Forums | Engine Developer Portal (vuforia.com)
So you can try here to use possibly the :
https://developer.vuforia.com/forum/device-and-platform-discussions/unity-development
https://developer.vuforia.com/forum/device-platform-discussions/mobile-devices
or https://developer.vuforia.com/forum/community-feedback/devices-and-hardware
Depending on that if you thing that this is more related to code or to device e.g. camera driver etc.
To be able to ask a question in the Vuforia Forum you need to register there which is free of charge: https://developer.vuforia.com/vui/auth/register
Thank you very much. I'm new here so I did not know that. I appreciate it
Hello, I am also creating my final project with Vuforia and encountered the same problem. May I ask how you fixed it?
