Can I change a background color of 2D widget?
yhwan
Hi
I'm making a demo project by thingworx studio.
I wanna change a background color of '2D' widget.
When I use a 'value-display' widget, the background color is white and font color is black.
Also, I want to change a color of button widget(2D).
Is it possible? if it is possible, please let me know how to do.
Thanks.
mneumann
(To:yhwan)
Sure...
you can change it through classes.
An easy example just to get to know the concept is creating a Button Widget.
In it's properties you can assign a class, e.g. "redButton" - this is the CSS class used for styling.
If in (left hand panel) Styles > Application​ you add a
.redButton {
  background: red;
it will allow changing the style and presentation of the particular slide with default CSS stylings.
When you now preview / publish the experience you will see, that the Button has now a red background.
I tested it and it's the same for the ValueDisplay.
srathoud
7-Bedrock
(To:yhwan)
Create a css class with your all color requirements and add it in "STYLES->application" and use the same class name in widget class field.
This will work.
Sameer Singh Rathoud
mneumann
(To:yhwan)
Sure...
.redButton {
  background: red;
