Can I zoom in ( out / translate ) the image with finger gestures?
i display manual image ( 2D ) and i will use finger gestures
zoom in / out / translate
is it possible?
Hi @wxywxy1 ,
so far I know, is not possible for 2d elements to zoom via gesture.
Currently you can use Pan , Rotate and scale for 3d elements in experiences with spatial targets. So, for example if you use 3dImage Widgets (e.g. with Billboard property set) you could have a similar effect.
Thank for Reply
The model moves with it, so it's impossible to use it.
Are there any examples created using 2D widgets?
The zoom function is replaced by a button,
Can I move images using scrolling?
Hi @wxywxy1 ,
I think , pan of 2d elements located on the panels (2d body /canvas) or inside a Grid is not really possible so that scrolling by the default behavior could work but this depends on the particular device - pan via scrolling could not always have the same behavior (e.g. difference between android and IOS)
I remember that when we have many 2d elements on a popup widget then the popup provides automatically scrollbars. Example:
or you can use an repater having different widget / also images:
Potentially y can also try to set dynamically and to vary the Top ,Bottom , lLeft or Right property of the popup widget, but actually I am not sure if it will react on the runtime file but still you can try it , may be it works
Thank for reply
I have a zoom buttons ( in / out ) and a single image in a popup
I want to enlarge the image with the zoom button and move the image to the scroll bar.
So far I know dynamic zoom is not possible because the width and height property could be set on start time but not change later dynamically.
One very simple option should be to use 2 different image widgets image-1 and image-2 and then define for each of them a click event with some code like this:
$scope.Zoom1 = function()
console.log("Zoom factor 1");
$scope.setWidgetProp( 'image-1','visible',false);
$scope.setWidgetProp( 'image-2','visible',true);
$scope.Zoom2 = function()
$scope.setWidgetProp( 'image-1','visible',true);
$scope.setWidgetProp( 'image-2','visible',false);
So that when you click the small image-1 widget then it will display image-2 and vice versa:
If this (simple) option is not ok for you - in this case you can try some think like the techniques described in: https://www.w3schools.com/howto/howto_js_image_zoom.asp
you can try to call this inside a popover = $ionicPopover.fromTemplate(). Actually I did not test it yet and have no idea if this will work. I think it could ... but this need to be tested.
