Can Vuforia studio play liveo video?
BSUN_RO
Hi there, I want to play a live video from a local camera, is this possible ? Thankyou!
6 REPLIES 6
@BSUN_RO ,
Could you provide more detailed information about your use case? Do you want to play the live video in your Experience via Vuforia View? If so, where can Vuforia get the source of the live video?
BSUN_RO
(To:Jimwang)
Yes, this is what I would like to achieve. I would like to play the video from a RTSP source or a http stream with mjpeg encoding. Thankyou!
If you have the source, you can check the below post and see if it is what you want:
https://community.ptc.com/t5/Vuforia-Studio/Video-widget-in-iOS/td-p/624901?posno=1&q=video%20widget%20ios&source=search
BSUN_RO
(To:Jimwang)
As far as I understand, that example is loading the binary from a local video source, but I have a http or a rtsp source. If I write any of the paths in the video source I get the error: "No video with supported format and MIME type found." Any way to display a web page on a 2d widget ?
@BSUN_RO
Per the below document, currently Studio only support MP4 and WEBM format.
http://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2FWidgetVideo.html
If you are using RTSP or other format, I think it is not supported. If you are using MP4, and try to set the source of the Video widget with http(https)://host/yourvideo.mp4 to see if it works.
BSUN_RO
(To:Jimwang)
I managed to play a video, but I want to play a live stream. Thankyou for your considerate support.
