Can't Publish since updating to Vuforia Studio 8.3.4
PB-Jacob
3-Newcomer
I was on 8.3.1 and it was publishing just fine, I updated to 8.3.4 and the publishing stopped working. I do not get any errors in Vuforia Studio itself, but it doesn't ever show the publishing progress bar, the publish and saves button grey out, and the log shows the following:
[10/09/2018 13:09:18] error: [twx-studio:index] uncaughtException SyntaxError: Unexpected token < in JSON at position 0
[10/09/2018 13:09:18] at JSON.parse (<anonymous>)
I have successfully validated the Experience Server and the only change was updating.
Locate publish.js and change line 37 to the following:
let mtgCapabilityParams = {};//body ? JSON.parse(body) : {};
I had this same problem and the change above fixed it.  The CAD target capability they had on the server was improperly handled.  The server returns something like <anon> which JSON.parse can not handle (and throws an error).
5 REPLIES 5
We are wondering if it is possible that the new version of ThingWorx studio application will not communicate with old version of On-Prem Experience server?  Our plan is to upgrade the ES.
chcote
(To:PB-Jacob)
Hi -
would you be able to provide some more info about the ES you are/were using? Is it a trial instance, PTC hosted, or on-prem? Which version was it?
We will put in a fix for this, but would like to better understand how it came to occur.
Thanks.  It's on-Prem server for which we are paying subscription on.  (not trial license..however, this ES version represents the version from the On-Prem trial).   Our admin is in process of updating the ES to a new version, so I don't know honestly if it is worth time trying to chase a permanent solution or not if we know the updated version will eliminate this issue.
I can get more details on the exact version of the ES, but if the new version resolves this issue, than I think we can ignore it.  I've already got something in place internally to make sure all our Studio user's get this change.
chcote
(To:BillRyan)
Thanks for the info. I suspect it's the older version of the ES that causes this behavior. I expect we will get the Studio change into the November release
