Can't accses to my experience from studio after publishing AR conten in CREO 4.x. My AR content was published in PTC cloud and I access it by ThingMark only. I need prepare experience with this AR content by using widgets from Vuforia Studio. How can I access PTC cloud from Vuforia Studio?
Hello Asiya,
Augmented Reality published from Creo Parametric or from Vuforia Studio are not published on the same Vuforia Experience Service.
Creo Parametric is using a custome and only one Experience Service hosted at PTC with some limitations.
If you want to have the 3D Model in Creo Parametric, you can import it in Vuforia Studio.
For that, please follow these steps :
Best regards,
Samuel
Hello Asiya,
Best regards,
Samuel
Hello, Samuel!
Yes, it helped. Thank you very much for the answer.
Hope you are doing good. Could you please confirm if the issue has been resolved.
If yes, please mark the answer as accept as solution for the future reference. Thank you in advance.
Regards-Mohit Goel
