I've been trying to make some procedures in my HoloLens, but when I try to sign in it throws the error "We can't connect to the service you need right now. HTTP 400 error".
Is this an organization problem or a VEC application problem?
I have a question :
The only thing, I have found is this company web site.
https://www.okta.com/products/authentication/
I guess that Jabil Okta is a software to manage SSO as Identity Provided and it is used by your company.
It is explained the issue about SAML bad request.
SAML is used in SSO.
Here for any reaon, SSO setup from Vuforia Expert Capture is not correct or request is modified on the fly.
It would recommend to report that to your IT.
Your IT should open a case to PTC Technical Support and we will be able to investigate deeper.
Why I recommend an investigation in a case and not in PTC Community?
Because in this use case, it seems security is impacted and we cannot share contents with everyone due to safety reasons.
Best regards,
Samuel
An HTTP 400 error means :
In your use case here, Vuforia Expert Capture should create a good request.
So, the possible root causes can be :
To start the investigation :
Best regards,
Samuel
Thank you for your response.
I tried to open the website, but it throws the same error after sig in:
The message says: "Bad SAML request".
I have published procedures in the PC, but I can't in HoloLens.
I have another question :
If not, it might be a network issue.
Best regards,
Samuel
Yes, both are in the same wifi and network.
I have a question :
Best regards,
Samuel
I will.
Thank you for your support.
