In multiple views,can one view correspond the Thing Template,and another view correspond the ThingMark ?
That means I view the first view by Thing Temliate and I view the second view by ThingMark,and the two views are in the same project~
thanks~Ankit GuptaQadir umargiriPai ChungImran Bagwan
Technically, your approach might work. Did you receive any errors while doing so?
Thanks,I'll try again
