Cant publish to ES after 8.4.5.4404 update
Rmcrabb
I cant seem to publish to my experience server after the 8.4.5.4404 update
7 REPLIES 7
dupatel
(To:Rmcrabb)
@Rmcrabb  Could you please confirm if you are facing an issue with all types of project publish like ThingMarks, Spatial & Model Target. There has been an issue reported to R&D with Model target so want to know if ThingMark & Spatial target is working or not.
Also, share the complete Studio logs to review.
-Durgesh
Rmcrabb
(To:dupatel)
The problem only happens with model targets. If I delete the model target I can publish.
dupatel
(To:Rmcrabb)
@Rmcrabb  Thank you for confirming and as advised for Model Target there is a known issue which has been reported internally & fixed under JIRA DT-23570. We are expecting the fix to be released in next release.
Possible workarounds on Windows-
  • reverting to previous version
  • setting serverMTG=false in builder-settings
-Durgesh
Rmcrabb
(To:dupatel)
I dont see the setting serverMTG=false in builder-settings
dupatel
(To:Rmcrabb)
@Rmcrabb  You will have to add this property and set value.
th3rdcoast
(To:dupatel)
We are having the same issue. Thanks for the insight. Silly question, where do I find the "Builder Settings" in order to try the workaround?
jvh
dupatel
(To:th3rdcoast)
@th3rdcoast - The builder-settings.json file  should be there in your Window dir -C:\Users\<Username>\Documents\VuforiaStudio .
-Durgesh
