Card Widget
Rmcrabb
Card Widget
Can someone explain the difference between the card and popup widgets? Maybe give an example of when to use each.
1 REPLY 1
The help does a reasonable job of this.
http://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2FWidgetPopup.html%23
http://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2FWidgetCard.html
in a nut shell popup is a container that popsup over whaever is on the screen. You can place other stuff in this container (grids, lables, images) and they will all show/hide with the popup. The Card lets you set up a tabbed 2D experience.
