Change a color of the 3D label via .js
MaximeDid
8-Gravel
How can I change a color of a 3D label by clicking on a button?
I tried to write the code below but it doesn't work:
$scope.SwitchConf = function () {
$scope.app.view.Home.wdg["3DLabel-2"].fontColor= 'red';
When I click on the button, the function "SwitchConf" is called but the color don't change.
Is it possible to do this by this way?
Thanks for your help...
Maxime.
Hi, @MaximeDid
Please try the attachment.
10 REPLIES 10
Hi, Maxime
What type of project did you create? Mobile or 3D eyewear?
I tried both codes below  and they work in my mobile project, in preview and on device.
$scope.setColorRGB = function(){
  $scope.view.wdg['3DLabel-1'].fontColor = "#ff0000";
or
$scope.setColorName = function(){
  $scope.view.wdg['3DLabel-1'].fontColor = "red";
Have you tried the code on device?
Sometimes it doesn't work in preview, but works on device.
Hi @dsgnrClarK ,
I created a mobile project.
I tried both code you send me, but in my app it doesn't works (in preview and on device).
I created also a new project and test the code but it doesn't work
I changed the code for check my function is called:
$scope.SwitchConf = function () {$scope.view.wdg['3DLabel-2'].visible = false;}
The result is OK.
Hi, @MaximeDid
Ok thanks,
I tried your code, and it's work.
So I copied and this is OK in my project also.
But I saw when I remove the line for modify the text, the color don't change. Do you know why?
The view does not seem to be refreshing...
Hi, @MaximeDid
Which version of Vuforia Studio and browser are you using?
Could you attach your project?
Hi @dsgnrClarK ,
I am using VuforiaStudio 8.5.15.4805 and Chrome Version 87.0.4280.88.
Please find my project in attachment.
Now I see the issue, but I don't know the mechanism behind it.
Sorry about that.
OK no problem.
I will only have to change the text to update the color.
Thank you for your help.
It looks like an update bug a work around
var currentText = $scope.view.wdg['3DLabel-1'].text;
$scope.view.wdg['3DLabel-1'].text = currentText+ " ";
$timeout(function() {
$scope.view.wdg['3DLabel-1'].text = currentText;
}, 500);
Thanks @sgreywilson ,
This is a smart solution.👍
