I want to change the buttons to be used according to the selection i made in select widget. Any idea how can i achieve it?
Also I am not comfortable with coding so a code according to my project will help me lot.
I am also attaching the exported project file.
Hi @manojpandey ,
what should happen here? I see there are some models already uploaded in the folder and you have a select.
Do you want to select these models - for display?
If no then please, let me know what is the issue - Pease provide more detailed information about the problem
if yes - so, I will suggest to having the following behavior:
To use the following code:
$scope.populateModelList = function() { $scope.my_json = [ { display: "Suspension Assembly", value: "app/resources/Uploaded/Suspension_Low.pvz" }, { display: "Arm Assembly", value: "app/resources/Uploaded/Arm_Assembly_Low.pvz" }, { display: "Front Hub Assembly", value: "app/resources/Uploaded/Front_Hub_Low.pvz" }, { display: "Shocker Assembly", value: "app/resources/Uploaded/Shock_Absorber_Low.pvz" } ]; console.warn( $scope.my_json ); $scope.view.wdg['select-1']['list'] = $scope.my_json ; twx.app.fn.addSnackbarMessage("assemblyList was populated","twLogo"); } $scope.$on('$ionicView.afterEnter', function() {$scope.populateModelList();});
Actually I want to place some buttons at the bottom of screen and I want that when i choose 'suspension assembly' some specific buttons should be displayed and when I choose other option such as 'arm assembly' some other buttons should be displayed and the previous one should hide.
Also when i switch window, operation done by the previous button should be disabled.
