Good Afternoon,
Can anyone help me regarding changing opacity of all parts of model in Vuforia Studio.
Example: If I click on a button opacity of one part should be 1 and rest whole model's opacity should be 0.5 & if I click on another button 2 part's opacity should be 1 and rest whole model's opacity should be 0.5, how can I achieve this?
Thanks in Advance.
when you press a button try to set 0.5 to the whole model opacity and then set to 1 the opacity of the single item.
Hi @aletenti2
Even I was trying to do the same & it did worked.
Thank You for your response.
Aditya Gupta
