Hello, I have a toggle button where pressed is play and unpressed is pause. While step is being played, the toggle button changes from play to pause and as soon as the step ends it changes back to play. Any other way to make this work apart from play started and play started events under model widget.
It might help if you can give a little more detail about where the event binding approach (play started/play stopped) is not working the way you would like. That's what I'd recommend for this, unless there's a specific reason it's not working for you.
