Hello everyone,
I was wondering how would i go on about connecting HoloLens 2 with Thingworx ?
I'm currently exploring the capabilities i could get out of the mix of the two. Maybe displaying a mashup?
Any insight about connexion protocol's and/or any sort of reading would be helpful.
Thank you in advance.
Could this tip be helpful to you? Link (read comments there also): https://community.ptc.com/t5/Vuforia-Studio-and-Chalk-Tech/How-can-we-make-a-3D-Widget-on-HoloLens-visible-in-front-of-me/ta-p/658541
I'd like to add that i'm considering using Vuforia on Unity
Hi @WB_9962145 ,
in generally the Vuforia on Unity as Vuforia Engine is only a AR feature which is added to Unity functionality and allow to track the video inputs of the device camera , the device sensor etc. according to the overview https://library.vuforia.com/articles/Training/vuforia-fusion-article.html
The Vuforia Engine functionality does not contains any functionality to access data on external servers ( expect the license features of Vuforia Engine check https://developer.vuforia.com/license-manager and Vuforia cloud when cloud targets are used according https://library.vuforia.com/objects/cloud-recognition
Therefore when you need to have a connection from your app (unity app) to a Thingworx server you need to implement this functionality by yourself e.g. as part of unity library - e.g. To access to some Thingworx functionality you need to be able to use some browser functionality to open a TWX mashup or to call a rest api call to the Thingworx server -> means to call TWX services and to received the results
I think the simples way is to use some rest API calls -> as mentioned in https://www.red-gate.com/simple-talk/development/dotnet-development/calling-restful-apis-unity3d/
The mentioned link describes the usage of the general rest API calls form Unity. To performs a TWX rest call you need to check the following related documentation links (below) to see the syntax of the call which should be sent to TWX server
https://www.ptc.com/en/support/article/CS329281
When you use Vuforia Studio on HoloLens (means without Unity) and the app is working inside the Vuforia View – In this case you can use the Studio External Data functionality (definition in external data UI panel) to receive data from executed TWX services and to get values of diverse things properties so that you could basically display this data using the Studio 2d and 3d widgets. This means the efforts is much lower compared to the implementation work of such connection to Thingworx in Unity.
