Hi Everyone,
I'm currently trying to display some properties of a thing that I have in a local installation of Thingworx Composer in an AR experience using Thingworx Studio. I have created the 3D model and imported it into Thingworx Studio and I also created Some gauges and labels to display the properties.
The problem that I have is How can I get the real-time properties values, from the thing that I have in Composer, to Thingworx Studio ? I tried to follow this guide but they show how to do it using a hosted version of composer already created by PTC.
I have searched a bit and I found that I need the Experience Service Extension installed in the local instance of Thingworx Composer. The question now is where can i download the Extension and how to install and configure it ?
Best Regards.
Are you using the Studio trial? If so, you will need to connect your local instance of composer to the trial thingworx using federation. A guide on doing that can be found here: https://community.ptc.com/t5/IoT-AR-Tech-Tips/TWX-Federation-Setup-Guide-docx/m-p/533533
