Connection between Vuforia Studio (trial) and ThingWorx (trial)
Rapha97
7-Bedrock
Hey,
according to this, it is not possible to connect the trial version of Vuforia Studio with the trial version of ThingWorx.
Is this correct?
Post: https://community.ptc.com/t5/Vuforia-Studio/How-to-connect-vuforia-studio-Trail-with-thingworx-foundation/m-p/582829#M4698
Thank you
Alessio
(To:Rapha97)
The ThingWorx instance included with the Vuforia Studio trial can be considered read only, that is you can use existing entities and read data from them but you are not allowed to create new entities
6 REPLIES 6
dupatel
(To:Rapha97)
@Rapha97  Yes,  that is correct. Studio trail comes with an integrated  ThingWorx trail associated with it which could be used however that instance has some restrictions & limits.
-Durgesh
Rapha97
7-Bedrock
(To:dupatel)
Thank you.
Where can I find those restrictions & limits?
dupatel
(To:Rapha97)
@Rapha97  You can log in to the Trial portal - https://trial.studio.vuforia.com/home/ and in the center, there is a Studio Getting started guide which has details. I am also sharing the direct link if that helps- https://s3.amazonaws.com/studio.thingworx.com/documents/StudioGettingStarted_Trial_en.pdf
-Durgesh
Rapha97
7-Bedrock
(To:dupatel)
On page 6 it says: "Access to ThingWorx is included with the Vuforia Studio trail."
Can I connect with this ThingWorx to the Azure-cloud or a copy of the cloud data?
Thank you
Alessio
(To:Rapha97)
Rapha97
7-Bedrock
(To:Alessio)
@Alessio und @dupatel thank you very much for your help.
I think I don`t have any further questions.
If I have other questions to this topic i will reply you in an answer.
