Is it possible to copy experiences downloaded to Vuforia View between clients, such as iPads, without going through a server?
I'm assuming this is for situations where the ThingWorx license has expired or there is no network environment to access ExperienceService. In the event of a client device failure, I would like to copy the experience to another client device.
This is not possible. Access to local drive is restricted.
