i want to create an AR, where in i will scan the Thingmark and when a Video should start.
Can anyone explain me how I can do that using Voice commands from the HMT-1?
@LauCz: I believe you can use the Video widget, to play or pause the video with a voice command. You will have to include a button and bind it to the Play or Pause service on the Video widget.
-Durgesh
-Durgesh
@dupatel: Thank you for your answer. That's exactly what I thought, but unfortunately I couldn't manage it. Do you know a good guide that I can try it again?
Laurenz
@LauCz I do not have any documentation or reference handy which I can share. Also, do not have HMT-1 device so let me check internally if someone else has more details to share here.
Please confirm me if this is something resolved and do not need details.
-Durgesh
