Creo Illustrate - Remove multiple keyframes at once (?)
Wes_Tomer
I am creating a sequence to use in Vuforia Studio. I selected 4 parts and moved them up, then across, then down. Each movement created a new keyframe for every selected part. I want to remove the last movement. Do I need to manually expand the track, find the part, expand it, find the keyframe, then select and delete it - for every individual part - or is there a way to do this for all of the parts in the track at once?
Also -- if there is a help resource, documentation, or another forum where this or a similar question has been answered -- can you mention it in your reply?
Thanks!
Wes
Wes_Tomer
(To:Wes_Tomer)
I figured one solution out -- expand each item in the "New Track" and then click and drag to select multiple keyframes (see attached)
Wes_Tomer
(To:Wes_Tomer)
