Data Grid Widget without Thingworx
Hello Community
Is there a way to use the Data Grid widget without TW?
Or is it possible to build something similar with repeaters?
Thanks for your help!
Alex
whityAnswer
whity16-PearlAnswer
Have a look over here:
How to create 2D components using Javascript from ... - PTC Community
cheers
whity
AlexK15-MoonstoneAuthor
Hi Whity
Thanks!
I did see that post, but it wouldn't provide the first line of the grid with all the row descriptions.
But it could still work, if I add the row descriptions as a line to the JSON response from the server.
IT would be nice to have a widget, that works without Thingworx.
Best wishes
Alex
It worked, I've made a static array with the labels for each row and made a new array adding the server data and the row labels, it is not the perfect solution, but it will be ok for now
