Data from Cortona 3D into Vuforia Studio project
vkrayushkin
Is it possible to use Cortona 3d content into Studio project  directly or by something? Any information welcome.
can you please elaborate more?
As per my understanding ill answer this question.
any cad which which supports vuforia studio can be imported and used in it.
supported CAD models list as below
http://support.ptc.com/help/vuforia/studio/en/index.html#page/Studio_Help_Center/SupportedCADFileFormats.html
Hi Suraj_Patil,
Thanks for your help
I know that Cortona saves  its Data into Cortona Server or on TeamCenter server. Other apps can read 3D from such server with help of Open/GL. The native format of Cortona is “the secret” for me now, but I suppose it may be VRML.
Right now I try to get Cortona  file(s) but need sign NDA for that  -> it will take a lot of time.
Anyway – I will inform you about my attempt.
Vladimir.
Hi @vkrayushkin ,
It seems that Cortona3d does not support the usual export CAD formats but so far I see this http://cortona3d.com/en/kb/articles/cortona3d-viewer-ios-supported-vrml-nodes  - so it seems to could save data to VRML format(no idea if this is the native representation or an option to export to VRML- I was not able to- find such export action in the Cortona3d knowledge base http://cortona3d.com/en/kb ) which is supported by Studio -  please, see link mentioned in the post of
@Suraj_Patil
pandersson
(To:vkrayushkin)
Cortana3D output consists of 3d models and animations, the 3d models should be possible to export into vrml but the animation is much more complicated. What usecase are you looking at, models only or models AND animations?
BR
Per
