Date picker
Jeremy3
6-Contributor
Date picker
Does anyone know how to make a date picker in Vuforia studio?
I added here the project where I tested this issue .
4 REPLIES 4
Hi  @Jeremy3 ,
so far I this possible in JavaScript we can incorporate a data/calendar picker into the Vuforia Studio environment. At least it works in preview. I did not test if this will work also o n mobile device but - I think it should.
E.g based on the follow link:
https://www.cssscript.com/tag/date-picker/
there are some data picker implmented- copy to downlaoded directory and load the lib and defined a function which is called from button:
$scope.loadjscssfile= function(filename, filetype){
  console.log("loading "+filename+":: type="+filetype)
    if (filetype=="js"){ //if filename is a external JavaScript file
        var fileref=document.createElement('script')
        fileref.setAttribute("type","text/javascript")
        fileref.setAttribute("src", filename)
    else if (filetype=="css"){ //if filename is an external CSS file
        var fileref=document.createElement("link")
        fileref.setAttribute("rel", "stylesheet")
        fileref.setAttribute("type", "text/css")
        fileref.setAttribute("href", filename)
    if (typeof fileref!="undefined")
        document.getElementsByTagName("head")[0].appendChild(fileref)
$scope.testLoad= function()
$scope.loadjscssfile("app/resources/Uploaded/lib/simplepicker.css", "css")
  $scope.loadjscssfile("app/resources/Uploaded/dist/simplepicker.js", "js")
$scope.$on('$ionicView.afterEnter', function()  {
  $scope.testLoad();
  $timeout(() => { $scope.setWidgetProp("button-1","class", "simplepicker-btn");
                  $scope.$applyAsync();
  },500)
//https://www.cssscript.com/material-date-time-picker-simplepicker/
// function called from a button
$scope.app.TestPicker = function()
  let simplepicker = new SimplePicker({
      zIndex: 10
   simplepicker.open();
   simplepicker.on('submit', (date, readableDate) => {
     console.warn( readableDate );
     $scope.setWidgetProp('label-1','text', readableDate);
    simplepicker.on('close', (date) => {
      console.log('Picker Closed' );
Then tested  the lib simplepicker:
Spoiler
Thanks for your help. It only works on AR view and not for 2D view.
Thanks for feedback,  but the answer is NO - it works for both - for 3D and 2D view - verified on Preivew and on android. Not sure /I did not tested on HoloLens
I attached a version of the projet where I added a 2d view.
Please, let me know if you  have questions
