any update about this ?
https://community.ptc.com/t5/Vuforia-Studio/Support-for-Creo-Illustrate-6-1-decals/m-p/649646#M7575
It has to be working : https://community.ptc.com/t5/Vuforia-Studio-and-Chalk-Tech/What-s-New-in-Vuforia-Studio-9-0-0/ta-p/706386
Sometime it is working, sometime not... Does it has some limitations ?
Hi there! Can you share a video of the workflow you go through when its not working? This will help the team better understand the issue you're facing
Hi, @AlexandreMG
Could texture in Creo Parametric be a solution to this?
Decals set in CREO Parametric as Texture, then Save As PVZ.
It can be a solution but I only want to use Creo Illustrate because many of ours customers do not have Creo Parametric.
any updates on this to use decales directly in creo illustrate?
