Is there a way to deploy mashup to HoloLens?
You can always deploy IoT data unto HoloLens i.e., using TWX services.
But if your question is about deploying the UI from ThingWorx, then I doubt if it is possible with Studio and moreover with HoloLens.
Fred Estes What exactly do you mean by "Mashup"? Are you trying to import ThingWorx Mashup in Studio?
yes, I have created a thingworx mashup in studio 8.0 and I was wondering if it could be deployed to HoloLens
Thingworx Studio doesn't support importing ThingWorx mashup.
Is there any other way to deploy IoT data from Thingworx to HoloLens?
Or, can Thingworx be accessed remotely using Microsoft HoloLens?
by open a web page?
if you really want to open a Mashup from Thingworx Foundation (NOT studio!) you can open a webpage in Hololens.
If you want to open an experience in hololens using IoT Data - giri has made the correct explanation.
You can display and also use IoT data in any end device.
martin
