Drawing attention to certain area.
Bhamb002
I am creating assembly instructions for our employees. I want to draw attention to a certain side or area of the model, regardless of where they are viewing the part. A leader line would work. I added insets in creo, but they did not transfer over into studio.
Hi @Bhamb002 ,
regarding to question how to  set attention to specific area -> you can move a marker to the position A marker  could be any 3d part like an arrow. you can  also set the color of specific component /highlight.
According to the Creo Parametric annotation - so far I know is this not supported in Studio. There are some old releases where this was working so far I could remember (please see the post)  Annotations from a model 3D in an AR project You can try if this is still working
Generally to the question about using of some annotation you can check the following topics:
and
Also relevant approach could be found in the CS article
