Hello!
There is a drop down selection option that shows the first option on the drop down, however I do not know where to go to access the other three options on the same drop down menu.
The sequence of lockout is the first option, but where can i find the other selections? There should be three more.
Thanks!
What product are you asking about?
This topic does NOT belong in the eSupport Help Discussions page.
Please when asking a question, navigate to the proper product page. You will get a faster answer.
My apologies!
Out of:
Which one would you recommend I use to tag this?
I am using Thingworx & Vuforia Studios.
Start at this page for any inquires and select the propoer product from the middle of the page.
