As far as I know, Studio currently doesn't support animation, it only supports Sequence created in Creo Illustrate so that any animation needs to be manually converted as Sequence steps in Creo illustrate then play the sequence in Studio to show the animation effect. It is too much user effort to try apply some common effect such as "emphasis" and "blinking" in Vuforia Studio. Lowering the working efficiency.
Is there a way to easily apply common animation effects such as "emphasis" and "blinking" in Vuforia Studio?
If the answer is no, then do we have any plan to enhance the product to add similar function to make user be able to easily apply some common animation effect inside Studio in the future release?
Good Point!. So customer may need to add the effect in Creo illustrate.
The effect is done by Javascript in Vuforia Studio.
I guess it would be possible to change the scale simultaneously, but haven't found out how.
