Easing animations not showing in vuforia
AY2021S1
6-Contributor
The easing animations that was done in creo doesn't show up in vuforia
6 REPLIES 6
dupatel
(To:AY2021S1)
@AY2021S1  Could you please provide more details regarding the issue like -
  • If possible share the snapshot of creo vs Studio
  • A version of Creo Illustrate/Parametric
  • A version of Studio
  • Is there any errors in Vuforia Studio logs
In case you have access to PTC Studio technical support than raise a PTC case to review.
AY2021S1
6-Contributor
(To:dupatel)
There's no error logs
The Vuforia version is 8.5.7.4613 , Creo illustrate is 6.1
This is creo easing animation, as you can see it functions as animated
https://youtu.be/dxuP4zj09xU
But in Vuforia the easing animation is not being animated
https://youtu.be/3TP2s_SqsME
dupatel
(To:AY2021S1)
@AY2021S1  Could you please refer to the attached image and confirm if you are using Creo illustrate an Animation?  You will need to create a Sequence in Creo Illustrate to have the required effect and then publish the PVZ file which should work within Vuforia Studio.
AY2021S1
6-Contributor
(To:dupatel)
If i used animation in creo i couldn't get it to play in vuforia
As for the sequence, yes i did export as pvz before using in vuforia
yanchen
(To:AY2021S1)
Officially, we don't support animation of Creo Illustrate to be used in Vuforia Studio, but there is a workaround to transform the animation to sequence in Creo Illustrate, then can be used in  Vuforia Studio, please check article CS266394, it is a little complex though.😂
WilsonT
(To:AY2021S1)
Hi @AY2021S1 ,
After checking, it seems like the easing animation is not supported in Vuforia Studio.
