Error occurred while starting
Sagar96
3-Newcomer
Hey all,
Installed Studio using run as administrator as well as created environment variable for working directory still it is showing error
kindly help me for resolving this issue.
Thank you
3 REPLIES 3
tmccombie
(To:Sagar96)
Can you share your log file as well? Select 'view logs' for the log file. This will help us to determine what is causing the issue.
Sagar96
3-Newcomer
(To:tmccombie)
 Please find below log files kindly help us for the same.
tmccombie
(To:Sagar96)
Thanks for the log file. It looks like localhost:3000 is already in use on your machine by another application. Please ensure port 3000 is open and unused. Then try opening studio again.
