External Data = Thingworx Only?
swstevens
If there was an existing IoT application already deployed that has relevant data for my Vuforia Experience, is there a way to get data directly from this 3rd party application, or must the data pass through a Thingworx entity property or service first and then into the Vuforia Experience?
Thanks!
So, this piece of code is running on my project:
$scope.your_api_name = function() {
    var your_url= 'http://<your_url_domain>';
    var data_on_json_format ={'name': your_name, 'surname': your_surname};
    var req = {// aggiunta Giovanni Panozzo 9.10.2020
      method: 'POST',
      url: your_url,
      headers: {
        'Content-Type': 'text/plain'
      }, data: data_on_json_format
    $http(req).then(function (response) {  //chiamata api_svc_ricevicarrello
        console.log(">> OK: your_api_name");
        console.warn(response);
    },function (response) {
        console.log(">> ERR: your_api_name")
I think you could also use http get/post method for sending/receiving data.
Take a look to: https://docs.angularjs.org/api/ng/service/$http
      method: 'POST',
      url: your_url,
      headers: {
Thanks.  I'll give it a try.
Worked for me, thanks!
Simple GET from world clock API updates the text of a 3D label.
http://worldclockapi.com/api/json/est/now
