I am iterating through images on a 3D image widget. With each step in a .pvz sequence I change an image accordingly. I noticed that capitalization of file extension can cause issues. In the Studio preview, it is fine, but after you export to an IOS device, anything image file that ends in .JPG instead of .jpg doesn't show up.
I think this is a glitch, since they should be treated the same -- but at least now I know what to avoid when generating images for my app.
I also found a quick fix. Create a text file with this in it:
Then change the text file extension from .txt to .bat (such as rename.bat)
Put the bat file in your images folders
Documents\VuforiaStudio\Projects\***your project name here***\dist\app\resources\Uploaded and:
Documents\VuforiaStudio\Projects\***your project name here***\src\phone\resources\Uploaded
Then double click on the rename.bat file, and all your images will automatically be changed from xyz.JPG to xyz.jpg
