Freeze animation
Jonny
9-Granite
Freeze animation
is it possible to stop an animation immediately?
In my case the animation just play the sequence till the end after clicking the stop button.
Thank you,
Jonny
Jonny
9-Granite
(To:Jonny)
FYI: I found the JavaScript command stopping the animation.
scope.stop = function() {
        // currently "stop" will only stop playback of a playAll when it reaches the end of a step.
        scope.continuousPlayback = false;
 The stop function is not programmed to stop or to pause the animation immediately.
Have you tried calling the Reset service on the model?
$scope.app.fn.triggerWidgetService('model-1','reset');
--Clay
Hey Clay,
the "reset-service" will reset my complete sequence. In my case I need a function that just pause the animation like a video player or like it is possible in Creo Illustrate.
Ah, I see, I thought you wanted to completely stop the playback, not just pause it. I haven't found a way to do that.
--Clay
