I know it is possible to get the length of the current sequence with $scope.app.view.Home.wdg["model"].steps however I would like to get the length of each sequence for the model, and store this in array.
Is there a way of getting each sequence length, other than creating a loop where I change the sequence and then get the steps each time?
For instance, if model-1 has
sequence 1: 10 steps,
sequence 2: 15 steps,
sequence 3: 7 steps
Is there a way to get this information without changing the current sequence multiple times?
In the end I will create an array [10,15,7]. This is useful for an overall progress bar I'm creating.
Wes
Hi Roland,
Thank you for sharing this. I'm going to stick with this "hack" method of getting the sequence lengths while in Vuforia View. It only takes a fraction of a second, and it works:
//I loop through the pvi files with a recursive function until I’ve collected the number of steps from each:
//‘no’ or ‘yes’ denote whether or not there is an animation associated with that learning chapter.
var chapters = [['intro','no',2,'incomplete'], //_________________0
['tools','no',6,'incomplete'], //_________________1
['components','no',3,'incomplete'], //____________2
['Float_5FValve','yes',9,'incomplete'], //________3
['Exhaust_5FFilters','yes',18,'incomplete'], //____4
['Antisuckback_5FValve','yes',9,'incomplete'] //___5
] // [0,1,2,3]
// Get chapter lengths *******************
var k=0;
var seqLenRequested = false;
getSequenceLengths = function(){
seqLenRequested = true;
if(chapters[k][1]=="yes"){
$scope.setWidgetProp('pump', 'sequence', "app/resources/Uploaded/ASSEMBLY-without54/l-Creo 3D - "+chapters[k][0]+".pvi");
if(k+1<chapters.length){k++}
if(chapters[k][1]=="no"){
k++;
getSequenceLengths();
// event listener for sequence loaded
$scope.$on("sequenceloaded", function (evt, arg) {
if(seqLenRequested){
chapters[k][2]=$scope.app.view.Home.wdg.pump.steps;
if(k<chapters.length){
Hi @Wes_Tomer ,
I don't think that currently we have a method to get the info about all sequences with steps.
There is in generally 2 possible solutions.
1.) you can extract the data outside Studio using Creo View Toolkit tools as mention in the post "Extracting the viewables and the seqnece steps information from a .pvz file for the usage in TWX"[1]
->Example for extracting of data : worldcar-brake-multi-figure.pvz
worldcar-brake-multi-figure.pvz-viewableSteplist.json
Here is a list of the steps of the vieable "Sequence" (viewable is Creo Illustrate Figure like a sequence , animation ...)
[{"viewablename":"Sequence","nr":0,"name":"Sequence","description":""},
{"viewablename":"Sequence","nr":1,"name":"Step 1","description":"Remove spring clips"},
{"viewablename":"Sequence","nr":2,"name":"Step 2","description":"Release 4 bolts"},
{"viewablename":"Sequence","nr":3,"name":"Step 3","description":"Pull apart the calipers"}]
worldcar-brake-multi-figure.pvz-viewablelist.json
Here is the list of all viewables - where some of them are Sequences. Currently only the sequences are visible in Vuforia View )
[{"name":"Figure 1","value":"Figure 1","type":"viewable","hasSequence":false,"hasAnimation":false},
{"name":"Sequence","value":"Sequence","type":"viewable","hasSequence":true,"hasAnimation":false},
{"name":"Parts List","value":"Parts List","type":"viewable","hasSequence":false,"hasAnimation":false},
{"name":"Sectioning","value":"Sectioning","type":"viewable","hasSequence":false,"hasAnimation":false},
{"name":"Translation","value":"Translation","type":"viewable","hasSequence":false,"hasAnimation":false},
{"name":"Animation","value":"Animation","type":"viewable","hasSequence":false,"hasAnimation":true}]
As further demonstrated in the post [1] we can load the data as json object to Thingworx repository and use it as in a TWX service to access the data from Vuforia Studio.
2.) Another option (as you already supposed in your post) is to start in JavaScript a loop where we will set the current sequence to each item in the Sequence List model widget property and check the Steps property.
This could be started only one time - in preview and saved to twx for later usage. Or it is possible to do this every time when we received the experience first time ... also in view but this could lead to some delay and flickering on start .
I did not test this approach by me self but I think it should work. If you have some difficulties to implement this , then please, let me know, so I will test it.
Hi Roland,
] // [0,1,2,3]
var k=0;
k++;
Of course, this overwrites each chapter length, so you can put anything you want in chapters[i][2]
The data can be used later to calculate the overall percentage complete.
] // [0,1,2,3]
It would also be possible to get the list of sequences with another function:
$scope.view.wdg['model-1'].sequencelist;
