Getting a "getaddrinfo ENOTFOUND fall" error when trying to start the Experience service.
Aparna
3-Newcomer
Installed an on-premise experience service and trying to start it using
sudo ./start-es.sh
but getting the error below.
Error: getaddrinfo ENOTFOUND fall
at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:64:26) {
errno: 'ENOTFOUND',
code: 'ENOTFOUND',
syscall: 'getaddrinfo',
hostname: 'fall'
vxs Process exiting with code: 1 +101ms
/usr/share/ptc/node_modules/q/q.js:155
throw e;
errno: 'ENOTFOUND',
code: 'ENOTFOUND',
hostname: 'fall'
What could the reason be and where should I check
3 REPLIES 3
dupatel
(To:Aparna)
@Aparna  Could you please start the ES using below debug mode command and review error-
DEBUG=vxs* bin/start-es.sh
Also, make sure the port used by ES is not already in use.
oparfon
(To:dupatel)
Hi! How exactly the command will look like?
ytella
(To:oparfon)
Could you please provide your OS details on which you have installed Experience Service. Is the installation completed successfully or have you noticed any errors post-installation? Have you started ES in debug mode? Please review the below article to start ES in debug mode. This will provide us more information on the issue:
https://www.ptc.com/en/support/article/CS292811
