Hi all,
Do anyone know if it is possible to integrate google maps, or any map service, into Vuforia Studio? In the case, how would one proceed?
Thanks, Paal.
Hi @pathorse ,
so far I know, there is no possible direct google play map integration. The question is - what your particular application case is and why you need to call it directly in Vuforia view
The google map could be used in thingworx mashup. So you can use a hyperlink widget to call a link to a mashup where your already inserted the Google map Thingworx widget.
But you could use any click events on any Vuforia studio widgets and call an external link via JavaScript
Hi @pathorse ,
