Good morning ,
I'm looking for an experience with Hololens.
By carrying out the survey with the Trackinq model the digital model is moved a few centimeters from the physical one. The same experience made for tTletlet overlaps perfectly with the model.
There are adjustments to be made to optimize the Hololens experience.
Other:
With Hololens you can share on another screen when using Vuforia View.
I have proved that TM is not detected if I am in sharing mode.
Matteo
Hi @Matteo_1987 ,
Could you please confirm if you are using 'Live Preview' on Windows device portal to view the experience. If you are not using Live Preview, could you please share the steps that you are using to share the experience on other screen.. I highly appreciate it if you could provide these details!
