Hide 2D overlapping elements during desing time?
anickolsky
Hi all,
How to hide existing 2D  elements design during desing time if they overlap with other 2D elements that needs to be created? Like infocards that are getting overlapped sometimes? It's not possible to create other 2D elements if existing one fills the space on the screen
7 REPLIES 7
dupatel
(To:anickolsky)
@anickolsky  Just to inform, I am owning your PTC Case related to this post and have reached out internally to see if there are any suggestions. Also, would be good to know if anyone else had similar challenges/experience during Designing and have any feedback/suggestions.
-Durgesh
InfinityX
(To:dupatel)
we are also facing the same issue while creating UI in vuforia studio (2D Canvas). I want to elaborate this question more from my side. while creating UI, suppose I  inserted popup widget there is hide popup option in properties.
like this way. Is there any another option to hide other widgets in canvas (not in preview).
InfinityX
(To:InfinityX)
pdf of hide popup property is attached here for reference
Swapnil_More
(To:InfinityX)
There is no way to hide widgets while designing UI (Except Popup Widget). It's better to give proper studio ID  for finding specific widget and add CSS(Padding, Margin) properties to overcome this problem.
Swapnil More
InfinityX
(To:Swapnil_More)
I know there is no away yet, I am giving feedback about it. It would be more helpful if there is option available in properties like hide popup. If we get same option in other widgets too in coming years, then that plays major role
Many thanks!
TomasCharvat
(To:anickolsky)
Hello  anickolsky
for this case I often use a workaround via CSS. If I need to hide a specific widget for design time I add a class to the widget which is defined for example by:
.hide {
  position: fixed;
  bottom: -10000px;
  right: -10000px;
The disadvantage is that you must remember which widgets have this class, because you must remove it before preview/publish project.
Tomas
