The Vuforia View app on the HoloLens is stuck in sleep mode. I have restarted the device, and the only solution I have found is to uninstall & then reinstall the app. However after closing Vuforia View, and attempting to reopen it, it becomes stuck in sleep mode.
Has anyone encountered this?
I intentionally gave this almost the same exact name as @bwhelan's post from 2018, since I can't reply to it, and it didn't resolve my problem. Microsoft is no longer performing updates on the HoloLens 1, so something else is causing the issue. Any ideas? @RolandRaytchev @jremb
I was able to get it working by using the Windows Device Recovery tool to wipe it clean and install a fresh OS. Then I reinstalled Vuforia View, and it works now.
The only cause that I have seen for this sleep mode situation is the HL update happening in the background. I realize that MS is no longer issuing updates for the HL1, but you should make sure that in fact the last available update is not still trying to self-install. Have you noticed other HL1 connected apps sleeping as well?
Apart from this, I suggest a call to PTC technical support if this only involves Vuforia View, or to MS support if the problem extends to other apps besides Vuforia View.
Excellent! Thanks for sharing your solution.
