HoloLens spatial target experience
AB00531937
8-Gravel
How to run spatial target experience in HoloLens?
Spatial target experiences show within the View library. After publishing your project, open View on your HoloLens to scan mode and say "Hey View, set experience service" then scan the QR code for you experience service. This can be found in the Info tab of your experience. Once you set your Experience Service, say "Hey View, show library". This should bring up your Experience library and show your published project.
Thank you for the response and the solution worked.
Avinash
