Hi All,
Is it possible to change the default location of the Project files that are stored on your local PC?
I can see from the Studio log file that it the initializer sets up a home and ThingWorxStudio dir:
[12/19/2017 13:44:36] info: [twx-studio:initializer] ThingWorxStudio dir: C:\Users\allan.thompson\Documents\ThingWorxStudio , home dir: C:\Users\allan.thompson\Documents
So is there an environment variable that controls the ThingWorxStudio dir option? Or is it hardcoded?
Many thanks,
Allan
the environment variable that controls the dir is your $userhome variable - if you change that env variable you would move your user directory in windows.
So, by using the launcher you can't change the project dir.
There is a way to launch studio in a different way - but it will be unsupported usage and as this I can't put that on the community.
Martin
Martin
Thanks Martin.
