How to disable the checkbox after user checked and uncheck if user click on reset button?
KM
I need to disable the checkbox after user checked the checkbox.I also need to uncheck and enable all the checkbox if user click on reset button. How can I do that?
Thank you in advance.
RolandRaytchev
(To:KM)
Hi @KM ,
this could be done with javaScript.
one possible option could be:
1.) from the checkbox Widgtets Value change event you can call the funciton e.g. goCheck which is defined somehow like this:
$scope.app.goCheck= function(checkboxname){
if($scope.view.wdg[checkboxname]['value'] == true){
$scope.view.wdg[checkboxname]['disabled']=true
and then wirte in the UI box : for the checkbox  e.g.:
this will  work only for one checkbox where you add the call to the javascript box - disadvantage  of this solution -you need to add to every checkbox widget in UI the function with the specific name. I think it will be possible to have  a more general solution but it will be more complex
2.) regarding to the quesiton how to uncheck and enable all checkboxes -you could start form the restet button some code like this:
$scope.app.resetCheckBoxes=function()
 wdgs=$scope.view.wdg
Object.keys(wdgs).forEach(function(key) {
 wdg = wdgs[key]
 console.warn(wdg)
    if ( wdg.widgetName.indexOf('checkbox') !=-1) {
       $scope.view.wdg[key]['value']=false;
	   $scope.view.wdg[key]['disabled']=false;
   $scope.$applyAsync();}})
and call the app.resetCheckBoxes(); from the UI Javascript box of Reset button
RolandRaytchev
(To:KM)
Hi @KM ,
 wdg = wdgs[key]
 console.warn(wdg)
KM
(To:RolandRaytchev)
Thank you
