Hi All,
I uploaded six images to Vuforia Studio and I want the following effect: when I click the nextImage2 button, the six different images are displayed one by one
here is the code I wrote.
// click button ,hide current image and show next image
$scope.nextImage = function (){
if ($scope.view.wdg['image-1']['visible']) {
$scope.view.wdg['image-1']['visible'] = false;
$scope.view.wdg['image-2']['visible'] = true;
$scope.view.wdg['image-3']['visible'] = false;
$scope.view.wdg['image-4']['visible'] = false;
else if($scope.view.wdg['image-2']['visible']){
$scope.view.wdg['image-2']['visible'] = false;
$scope.view.wdg['image-3']['visible'] = true;
}else if($scope.view.wdg['image-3']['visible']){
$scope.view.wdg['image-4']['visible'] = true;
}else{
$scope.resetImage = function (){
$scope.view.wdg['image-1']['visible'] = true;
I have encountered two problems.
The first problem is: In the 2D canvas, I can only put down 4 images and the remaining two images cannot fit in the canvas. How can I put all the pictures into the 2D canvas?
The second question is: I created two buttons and gave them the same function($scope.nextImage), but only NextImage2 can call the function properly. Why can't NextImage1 call the function?
I uploaded my project file and hope someone can help me with this problem.
I would only place one image widget and change the source of it like this:
var currentImage = 0
currentImage++;
switch(currentImage){
case 0:
$scope.view.wdg['image-1'].imgsrc="app/resources/Uploaded/v2-85586d9840e6267231a4a4381a3face8_hd.jpg";
break;
case 1:
$scope.view.wdg['image-1'].imgsrc="app/resources/Uploaded/v2-8bad62ab4301bbb336f25153c9698788_hd.jpg";
break;
currentImage = 0;
For the second question it seems like you cant place the button in the headerButton widget. Outside of the widget the button works fine.
currentImage++;
case 0:
break;
case 1:
break;
currentImage = 0;
