We have installed vuforia ES OnPrem, but when we start process i.e. ./start-es.sh then it runs and stops after some time once session get close.
So how to run the vuforia ES service continous, no need to start frequently?
Prashant Pandarkar
If you are in Windows, you can follow up this article :
https://www.ptc.com/en/support/article?n=CS309600
In CentOs, in Linux, we can use SystemD to manage Service (it is common under Linux)
More details here:
I have used both and they work like a charm.
Best regards,
Samuel
