How to scale in and scale out 3D images on triggering visible function
Ace_Rothstein
8-Gravel
 Is it done by Javascript or can CSS animations be applied to 3D images
Hi @Ace_Rothstein ,
I review the video link what you mentioned in your post. Unfortunately I do not know exactly how it was exactly implemented  here  , but I think this effect could be done by moving the 3dImage widget e.g. in Z direction and scaling the 3dImage at the same. time.
I did test it in a simple project, and I think it works.
So have only 2 widgets 3DImage-1 Widget and toggle-1 Widget. So, I used the click event of the toggle to FlyIn and FlyOut effect. It is not perfect but works.
I used the following code:
var zMax=2
var zMin=0
var dist = zMax - zMin
var moveTime=2000 //ms
var moveTimeStep=10 //ms
var distInt= dist/(moveTime/moveTimeStep)
var scaleFactor =0.92
var scaleMax=0.3
var scaleMin =  scaleMax *( Math.pow(scaleFactor,(moveTime/moveTimeStep)))
$scope.app.FlyIn  = function(){
console.log("called app.FlayIn()")
$scope.setWidgetProp('3DImage-1', 'z',-zMax)
$scope.setWidgetProp('3DImage-1', 'scale',scaleMin)
$scope.setWidgetProp('3DImage-1', 'visible',true)
$scope.setWidgetProp('toggle-1', 'disabled',true)
var tt = setInterval(function(){  $scope.startFlayIn() }, moveTimeStep);
setTimeout(function() { clearInterval(tt);
                      $scope.setWidgetProp('3DImage-1', 'scale',scaleMax)
                      $scope.setWidgetProp('toggle-1', 'disabled',false)
                      }, moveTime);
$scope.app.FlyOut = function(){
console.log("called app.FlayOut()")
$scope.setWidgetProp('3DImage-1', 'z',  zMin)
$scope.setWidgetProp('3DImage-1', 'scale', scaleMax)
var tt = setInterval(function(){  $scope.startFlayOut() },moveTimeStep);
                      $scope.setWidgetProp('3DImage-1', 'visible',false)
                      }, moveTime);
$scope.app.ClickAction = function(){
if($scope.view.wdg['toggle-1']['value']==false) $scope.app.FlyIn();
 else
 $scope.app.FlyOut();
 $scope.startFlayOut = function(){
  var newVal= parseFloat($scope.view.wdg['3DImage-1']['z']) -distInt
  $scope.setWidgetProp('3DImage-1', 'z', parseFloat(newVal))
  var newScale= parseFloat($scope.view.wdg['3DImage-1']['scale'])*scaleFactor
  $scope.setWidgetProp('3DImage-1', 'scale', parseFloat(newScale))
  $scope.$applyAsync()
 $scope.startFlayIn = function(){
  var newVal= parseFloat($scope.view.wdg['3DImage-1']['z']) +distInt
  var newScale= parseFloat($scope.view.wdg['3DImage-1']['scale'])/scaleFactor
I attached also the test project
3 REPLIES 3
Can you describe your use case in detail?
In the example mentioned here: (https://www.youtube.com/watch?v=ERa8sN837h0. ) Half way in the middle of the experience, there is an effect added to the 3D images which makes it appear to scale up after triggering some button.
Howden, a leading industrial engineering company, used #IoT and #augmentedreality (@ThingWorx and @vuforia) to create a #digitaltwin of their diaphragm compressor. This step-by-step manual delivered in augmented reality empowers technicians and others with real-time access to relevant information
Hi @Ace_Rothstein ,
var zMax=2
var zMin=0
var scaleMax=0.3
                      }, moveTime);
                      }, moveTime);
 else
