I need to make movement of robot in accordance with value from Thingworx composer
Nithin
The problem is whenever i drag and drop modelitem onto the part i want to rotate
the coordinates are setting to middle of the arm and its rotation doesn't depict the movement of arm in actual.
Please help me with solution.The picture shows the problem
sdidier
(To:Nithin)
Hello Nithin,
Did you have a look to this post of Roland ?
https://community.ptc.com/t5/Vuforia-Studio/Mechanism-Concept-in-Vuforia-Studio-How-to-make-rotation-more/td-p/552743
It described solution to control rotation axis of models.
  • Is it helping you ?
Best regards,
Samuel
Nithin
(To:sdidier)
Hi Samuel,
No Samuel
it ddn't work for me. I was not able to adjust robot arm using that script to correct position.
sdidier
(To:Nithin)
Hello Nithin,
Can you please provide your Project?
It will help to investigate and to find a possible solution.
Thanks in advance for your help.
Best regards,
Samuel
